marcus_cupra
hi guys
i've owned my silver 280bhp porsche wheeled cupra (formally JJ_arosa) for around 6 months now and it's time for a new clutch....
am i right in saying i need the 2.8 golf vr6 clutch???
Is this the right one
http://www.eurocarparts.com/ecp/c/V...c537f0c977859447b78f18b900cfa3f4a6b115dc&CLUK
And also i've been told i will need 8 vr6 fly wheel bolts aswell as the old ones can't be reused when they've been taking off is this right??
And will i need any other parts for changing the clutch etc
many thanks :happy:
ive already got the fly wheel on there buddy.... :p
just need a new clutch as it's slipping...
so thats definitly the clutch.... so if i already have the flywheel on there will i still need the flywheel bolts as i've been told that they have to come off to change the clutch and can't be reused???
Is there anything else i need??? release bearing or anything??
You can see the release bearing in the picture there, it's part of the kit. I'm not sure if the flywheel needs to come off to change the clutch. You will need the pressure plate bolts, and be aswell getting flywheel bolts while your there.
You might need a master cylinder as well. Some people do it as piece of mind, some people don't. Just if it goes then you will have to get the gearbox off again.
The clutch kit is correct & comes with new release bearing.
These are the bolts you need from VAG (you probably have one set already since you have the flywheel, but not sure which one it is):
N10 101 001 x 6
N90 206 103 x 6
Isnt the one on the clutch side the slave cylinder?
just had a quick search for your posts mr_D and couldn't spot the part numbers one... dont suppose you can quickly get the link as im sure you'll know which one it is :clap:
And as for the pressure plate bolts... what are these and what do they do??? Do i definitly need to get some?? And can they be purchused off ecp??
sorry about these noob questions... im abit of an amature :(
I have the bolts. Part numbers are N10117405 x6 and N10101001 x6.
If you buy them off me that would be greatly appreciated as I bought them recently and have no use for them...
do i definitly need both of these???
so if i buy those both off you and the clutch off ecp what else do i need???
omg 2 stelfs what the hell you doin guys . when you redoin yours mate
got told some people do it just as a piece of mind...is it not worth doing then ??
