Hi mate, I too have read conflicting info with regards to this,.
As far as I'm aware the Forge spacer won't fit with a revised D Spec OE valve. But, I'm sure somewhere on hear someone posted it does, hence the confliction lol.
As for fitting the oe type valves, there dead easy. Give me a shout if you get stuck, I know Ponte quite well.
Are the upgraded OEM D spec valves now fitted as standard or is it still an upgrade? If so does anyone know when they were fitted as standard from and can you easilly tell by looking at it which one it is?
Not sure mate, but you can easily tell if you remove the three torx screws and view the business end.
