Wow 33-35 seems high.
Does it say 33 inside the cap? I remember it saying 30-32psi like most cars.
That's what mine has always had![]()
There are some massive vehicles that are used in places like northern Canada and the like that have many wheels, and massive tyres at very low pressures that are used to move over the snow, and even swamps. The low pressure means that they actually put less load on the ground beneath them than a human foot, yet they weigh something daft like 16 ton. So, they don't sink through the snow to get to solid surfaces beneath them (bearing in mind that this could be feet below, not just a couple of inches), they spread their weight like snow shoes and drive on top of the snow.depends on conditions really , i know you can let air out to give wider grip ,
but also hear people putting narrower tyres on for the snow , so contradictory really ??
Um, no, tyres may be designed for different tasks (race tyres for example being grippier but lasting for less time) but ultimately the basics are the same, it's called physics. if you lower the pressure in them they spread out more and apply less pressure to the ground below. They also warm up quicker, and move around more. You're much more aware of these things on a bike than in a car, granted, but it still affects a car just as much. The example of the big fook-off machines in Canada and a race car (I said F1 where?) were extreme examples to exaggerate the effect. I could have said "try highly pressurised slicks on ice or low pressure winter tyres on the track in summer" but I chose to exaggerate a bit more, my bad. The fact is still there, and the whole "the manufacturer says this so that's how it is" argument is rubbish. It's EXACTLY the same as best-before-dates; you can go over and probably be OK, but they're covering their own backs, just in case. You should only deviate from the recommended if you know what you're doing, sure, but to say that you only need change pressures if you're on a race track is not true.Antnee
Your comparing a purpose built snow going vehicle and a formula one cars tyres to a road going cars summer tyres with a different pressure in them????
There is no link between these three.
Your basically saying that summer tyres with a lower pressure are as good as winter tyres is not true.
The tyre pressure should be kept at the manufacturers stated pressure no matter what the driving conditions/temperatures.
This should only be changed when driving on a 1/4 mile strip or a race track.
All other times it should be at 33PSI
Me too, never back down under any situations especially when I'm stuck offshore for Christmas and New year and pissed off.Agreed. You should be impressed with me anyway, I think that's the first time I've ever backed down from any kind of argument at all. I must be getting old![]()
