Tip tronic gear problem
nicbad
Hello there,
I noticed that when I drive my car using the tip tronic gear, it takes ages to shift down to the lower gear level; that's a bit annoying when you need to reduce the speed to avoid excessive use of the break. can anyone please advise? Thanks a lot
nicbad
OK I was not really asking what you had installed, more to use them in "manual" mode
Also "Sport" mode engine "brakes" more than "Auto" mode
sorry i misunderstood your reply; actually the thing is that when the rpm is high and i want to decelerate speed I only shift to minus "-" and the gears reduce from 5 to 4 to 3, etc... however when the car speed is slower and the rpm low, gear don't shift that easily. does it have to do with the rpm?
Bedlam
868
236
North Yorkshire
Just keep changing down (i.e. flick/flick/flick), the car will not let itself over rev, perhaps that is what you are describing?
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
If by pushing + the engine would stall the gearbox will delay until the speed/revs are ok to go into that gear and not stall. on the flip side the gearbox will delay if you attempt to push - and select a gear that would make the engine over rev too
Maybe you need to keep an eye on the rev counter a bit.
nicbad
I checked again, when the rpm is below 3000, the gear won't shift down easily
nicbad
Sadly I would say you have a problem, mine changes up/down in all rev ranges unless the change would over rev the engine
Thanks man, I will seize the opportunity of my 5000 km to check-up soon, to ask my dealer about the issue. Hope they will resolve it. By the way I drove an Ibiza (old body) and tried its tip tronic gear, it rev easily whatever the car speed
Bedlam
868
236
North Yorkshire
Be interesting to know the outcome after you take it in etc.
