Wiring help! unknown connections!
kyle18uk
464
Nottingham
Hello,
Well im nearly finished with the engine conversion, everything is in and I have plugged in what I can of the loom but im left with some plugs that im not sure about! Im not running abs or aircon so I guess a few will be for that, if someone could tell me what these are I would really appreciate it! (theres alot!!)
On the drivers side –
Near the brake reservoir,
4 pin oval connection, black, white, black/brown, white/red
2 pin. Brown/blue
Long wires,
4 pin square, black/red, blue/black, white/blue, green
2 pin, brown, white/yellow
Left short,
Big 2 pin with blue connectors, brown, purple/black
7 pin oval –
yellow, grey/red, black/green, white/red, brown/white, white, brown
2 pin white, green/yellow, blue/black
Also, there isn’t a plug for the headlamp?
Passenger side
Near the washer tank position – Unsure which one is for washer tank?!
2 pin, brown/green, brown/blue
2 pin, green/white, brown
Long wire near headlamp,
2 pin, white/yellow, brown
Big 2 pin with blue connectors, black/yellow, brown/black
Very big 4 pin, thick wires,
Red/black, red/white, red/yellow, brown
Running past power steering tank,
1 pin, red
1 pin, blue
2 pin, red/black, blue/black
Also , Im running my battery in the boot and didn’t have this on the 1.4, All ive got is a single cable from the positive from the battery running to the engine bay, how do I connect this up now?
I know this is a lot, but if you could just tell me what one of these plugs does it would really help!
Sorry for the dodgy iphone pics!
Thanks, Kyle
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Pic#1 (4 pin (3+1) looks like lambda sensor
pic#2 (4 pin) looks like temp sensor on top of oil filter housing (black/yellow strip
pic#3 or#7 is the rad fan wiring ?
pic#4 looks familiar
pic#9 starter motor wiring/gearbox area ? especially if one is blue
pic#10 is radfan control unit iirc
ill try and get some pics tomorrow of a few area's , with that many unplugged you should have a few holes to fill up no ?
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
pic #3 = rad wiring for fan (oval = AC, other = non-AC)
#7 = oval AC fan connector (see above)
#4 = headlight connector
#9 = looks familar, i think it might be on the thottle body, does it have like a bobble on it?
i hate it, cos they all look familar
just one question, how have you got a switch for an AC fan, and non-AC fan? as i require this (as i just got a twin fan with that connector)
kyle18uk
464
Nottingham
This is the thing there arnt many empty connections! If i know which ones are for air con and abs that'll loose a few unknowns.
Photos would be a great help tho if you dont mind, would really appreciate it!
kyle18uk
464
Nottingham
so the big oval 4 pin is for the rad fan and the big oval 7 pin is for aircon rad fan?
Not sure how ive got both to be honest, its a abf loom from a cordoba sx if thats any help?
kyle18uk
464
Nottingham
Ok, the ones I really need to know are -
Passenger side, near the washer tank position – Unsure which one is for washer tank?! and what is the other one for?!
Long wire near passenger headlamp,
Big 2 pin with blue connectors, (one on each side) black/yellow, brown/black
which connector is for the horn?
also, there is a springed switch which i guess is an alarm sensor for the bonnet? do i need this connected as I dont have an alarm?
Thanks, Kyle
kyle18uk
464
Nottingham
Another question, the fan wiring has 4 wires -
but I'm using a slim line fan that only has a positive and negative, so would I join the three red wires together and connect to the positive then the brown to the negative?
I thought that there should only be three wires? A negative and fast and slow speed wires, so what's the other for?
