Mar 1, 2009
1,079
Liverpool
Im wanting to replace my front wheel hubs, as the previous owner has snapped the brake disc location screw inside the hub.
Have just been looking for prices and found this:
http://www.eurocarparts.com/ecp/c/S...1f90d91a9b6ff073c7c11922d501f38bf8d3ab8e&WHUB
It says the hub contains the wheel baring? Is this correct?
Will the new hub come with the wheel baring inside?
I have a baring on its way out anyway, if I can just replace the whole hub then it will save me taking the car somewhere to have the new bearing pressed in.
well its out of stock and i thought they stopped selling hubs so i would ring up but i dont see how they do the nearings connected to the hub as you have to circlip and press them into the hub carrier,
Just read it again and it looks like theyre just explaining the area it fits too and reason for replacement so definately would call up see if theyre going to get these back in stock because im sure its just the hub
Cheers for the advice,
Im currently trying to figure out why my Brembo brakes keep warping, iv been through numerous sets of pads and discs, I just want to get everything right before I replace the brakes again.
This involves replacing the hub, as I think maybe the hubs I have at the minute may be slightly warped aswell.
If im changing the bearings then I guess I may aswell replace the hubs whilst im at it I guess.
Ordered some new wheel hubs from euro car parts yesterday, the reason why they show up as out of stock is because they are on special order.
Should have them next week.
Think is, i'm wanting to replace the wheel bearings as well but didnt order any.
Im hoping there will be new wheel bearings in the hubs they are supplying, is this usually the case?
Thanks.
