your not being detailed enough what exactly are you getting done if its lights then an exhaust system won't affect it...if its an engine or emissons etc then prob yes, bit hard to answer that question you posted though
Its the dash that i'm having checked out, as i am getting a very annoying vibration like sound coming from the center, perhaps from the cd player or one of the air vents.
Thanks for that Paulie, hopefully it should be okay as it's the bloody dash that is annoying me with the constant vibration coming from the center! Searching some of the threads, I'm aware it's a common problem with leon dash...
If they can't find anything they may very well say 'it could be where the new downpipe is fitted and the noise is being transmitted through' 'we'll charge you labour for the troubles'
My engine had all the signs of a diverter valve failure and they had a fettle around. They found I had a jubiliee clip instead of a spring clip on my air box so decided to not do anything under but charged me for labour. After a big rant I got the money back... just be aware that they'll do anything not to do it.
They have to follow a symptoms guidline sheet if yours doesn't fit the bill they won't bother.
