Prebs
662
Norway, Bergen
Hi. I installed a spec 3+ clutch and G60 fly a while back ago. Now I`ll be trying to find TDC in a short while(top dead center) Will I still find a mark on the new G60 fly?
Prebs
Yeah thats a good point, you could use the mark on the auxhilary drive belt pully, remove it then mark the crank pullys position with paint so you know where it should return to when timed up and you could remove the plug on cyl 1 and pop a long welding rod down to check its definatley at TDC.
