Hi All,
Attempted a cold start on my 2.0 PD engine this morning - it was having none of it!
Turned over, nothing there at all. Called breakdown recovery, left it half an hour, it sounded slightly more like it wanted to, but only slightly! Breakdown sprayed eazistart (well, brake cleaner) into the air intake and 10 seconds later it was running no problem!
Trying to put together a list of things which could be wrong:
Coolant Temp Sensor (Is this the same as the thermostat? If so, this was meant to have been replaced less than 3000 miles ago!)
Bubbles in the fuel line
Dodgy/blocked fuel filter
Anything else? Is VAGCOM likely to be of any use?
PS, should say, its done this before. Sometimes its extremely lumpy and does not want to go, and twice its just not started (leaving it 24 hrs has resolved this).
) then mine will then start
