steering rack bush fitting?
Feb 26, 2009
5,275
Wolverhampton
From what I saw when I was underneath the car, there's not much to it. When I considered doing it, I thought that access would be an issue. But someone suggested going in from underneath, and he was right. As far as I could see, it's a handful of bolts, nothing really difficult apart from actually getting a spanner on to them.
Get your front wheels off, get your head in the arches and take a look, you should be able to see what you're aiming for. Just do one side at a time and everything should stay in place.
Sorry it's not an actual guide, but hopefully it's a little bit of help...
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Two bolts on each side of the rack. Driver's side mounting is trapped by the arb.
I've only done it with the subframe dropped, not sure if there is clearance with it in place. Worth a try though.......
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
so does the rack itself have to move to get to the bush, or just lower the subframe and its accesible? sorry, never done this one tbh. and to lower the frame sufficiently, which bolts will have to be undone?
james walker
May 24, 2007
5,121
retford notts
ok dave thanks, take it the wishbones hold the frame when lowered, just support on trolley jack?
once lowered is the bush easy to get to?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Never dropped the subframe with the wishbones connected to the wheels. I suppose it depends how stiff your bushes are as to how much the subframe drops. You might get enough clearance without actually completely removing the subframe mount bolts - just unscrew a long way.... The bush is reasonably easy to get at - very easy with the subframe on the floor.....
james walker
May 24, 2007
5,121
retford notts
tt rear wishbone bushes thats all...
once access to the bush, im guessing undo the 2 bolts on the clamp, bush is on pasenger side yeah?
bush out, regrease new one in tighten back up.
seems simple enough.. next job for me then.
Ronin225
4,652
22
Worcester
Thread revival time
Thinking of doing this over xmas as bush is pretty cheap and i have 3 weeks off
Further up here it says ARB is trapping access for drivers side mounting is this not the case for LCR due to different shape ARB or does it still foul it??
Car is in need of realignment as front subframe was dropped to fit bigger downpipe a few weeks ago, so would rather do it now than pay for it twice
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Thread revival time
Still traps it.
