Squeaky brakes
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
Hey guys, I've had squeaky brakes for as long as I can remember, had my car serviced and MOT'd and neither have said any problem with brakes so I assume it is neither the pads or the rotor.
They REALLY squeak very high pitched and loud as it's starting to annoy me now as when the weather is nice and the windows are down it is very piercing.
I'm stuck at what to try as I've no good knowledge of mechanics.
My front bushes are worn and I need new brake fluid but these will be done before end of month but I don't think either of these could be causing the issue.
Help!
eugenebd
77
colchester
could be you pads! what make are they? ebc tend to squeal like a pig with its nuts cut in the wheel arches!! and should have anti squeal plates or alike.
loads of copper grease on back of pads as said above or try braking from high speed and hard to clear any glaze off the pads.
so annoying and embarrassing i bet
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Had the same thing myself, turns out my brakes didn't have grease on them
Greased up the brakes and worked a treat
