VAGCOM - Birmingham Anyone??
RVP09
130
Hi chaps,
I have been trying to get to the bottom of a problem i'm having with my turbo (see http://www.seatcupra.net/forums/showthread.php?t=251970 ) and have been advised to get my car hooked up to a VAGCOM, which I have no idea what that is or how it works.
So, does anyone here live in Birmingham or near Birmingham who has a VAGCOM and would be kind enough to read any fault codes for me?
Thanks in advance..
Feb 26, 2009
5,275
Wolverhampton
I seem to be spending my time between my home town of Wolverhampton, and my current contract in Coventry. If you can get to either location I'm sure we can take a look.
RVP09
130
Coventry seems good! What days/times are you there?
RVP09
130
I'm surprised with Birmingham being such a big city that there isn't anyone with VAGCOM :=(
b21playa
oil burner
Jan 10, 2005
544
Birmingham
im in birmingham and happy to read codes
beeer tokens always appreciated
where about in brum are you, im in great barr
RVP09
130
I'm in yardley - can you PM me your post code mate?
And are you free on the weekend?
Cheers!
b21playa
oil burner
Jan 10, 2005
544
Birmingham
Cheers!
Hi
Im in Great Barr, B42.
Free evenings if you want to pop over. I'll scan the codes, and can store them before clearing them.
I'll help as much as I can. I'm pm you my number, drop me a text to arrange.
b21playa
oil burner
Jan 10, 2005
544
Birmingham
hi mate
fault codes as scanned yesterday
VCDS Version: Release 908.0
Data version: 20090911
Wednesday,09,June,2010,20:36:51:13314
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ4xxxxxx Mileage: 214970km/133576miles
Address 01: Engine Labels: 038-906-019-ARL.lbl
Part No: 038 906 019 KG
Component: 1,9l R4 EDC 0000SG 5342
Coding: 00002
Shop #: WSC 06402
VSSZZZ1MZ4R084548 SEZ7Z0C2331107
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001 001 00001
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00044
Shop #: WSC 06402
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 922 E
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05424
Shop #: WSC 00000
1 Fault Found:
00771 - Fuel Level Sensor (G)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
Part No: 1C2959802A
Component: A7 Tõrsteuer.FS KLO 0202
Part No: 1C2959801A
Component: A7 Tõrsteuer.BF KLO 0202
Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0202
Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0202
1 Fault Found:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1M0 035 186 J
Component: Radio GRO 1 24
Coding: 00403
Shop #: WSC 06402
1 Fault Found:
00857 - CD Changer Unit (R41)
49-00 - No Communications
End ---------------------------------------------------------------------
RVP09
130
Nice one for that b21playa! Thanks for your help yesterday, top man!
I can't see anything there that remotely suggests turbo issues? That's all comfort stuff.
Yeah, I know. That's what's puzzling me! Though I did take it for a spin, got i up to about 85mph an the turbo didn't cut out. But I know that the problem definitely exists 'cos it's happened on the motorway twice in the last 2 months!
So what do you recommend/suggest? EGR valve clear-out?
Also, what do the other fault codes mean? Are they all electrical faults, and if so, is it expensive to sort out?
Cheers.
Feb 26, 2009
5,275
Wolverhampton
I'd ignore the intermittent ones, they may just be ghosts in the system. The interior sensors may have been unplugged, I'd be surprised if all four have failed at the same time. And the same with the CD changer, it's probably just been unplugged. Don't forget, those codes will remain even after they've been plugged back in again, so you might be looking at expired codes.
Did b21playa reset the codes after he read them? If so, do a few hundred miles then check the codes again. You might find that they don't come back, in which case there's nothing to fix.
RVP09
130
Interesting. I no longer have my CD changer as I took it out and replaced it with the Connects2 mp3 device, and as for the other codes, I had that cylindrical thing under the back seat (the fuel thing) cleaned out a few months ago, so would that explain the other codes? I mean my fuel level indicator on the dash works absolutely fine, no problems, as well as the temperarture sensor so I think you may be right, perhaps it may have just logged them..
As for the codes being cleared, i'm not sure... b21playa, did you clear the codes..?
b21playa
oil burner
Jan 10, 2005
544
Birmingham
yep after reading the codes and taking a copy, i cleared all the codes
is the turbo still cutting out?
RVP09
130
I haven't had time to hit the motorway yet, but when I took it to 80/85mph that day, it didn't cut out and normally it would. But i'm gonna take it down the M6 tomorrow evening to test it out again..
Will keep you posted.
Feb 26, 2009
5,275
Wolverhampton
How do you get it to 80/85 on the M6? I'm lucky to see 50! :D
