Jun 11, 2026
Hi,
I am trying to fix Formentor VZ310 that has ABS faults. I have replaced wheel bearing with ring already, I have also tried replacing wheel speed sensor (MEYLE), but after driving for longer I will get all sort of errors in the dash including ABS fault.
I have tried scanning for faults using VCDS (please see attached file), but I can not clear the codes using VCDS, but when I borrowed OBDEleven from a friend faults could be cleared but still come back after some driving.
Anyone experienced something like this. Maybe it is the ABS control module? Do I need specific wheel sensor (OEM)?
  • Log-VSSZZZKMZMR005368-127046km-78942mi.txt
I measured left side wheel speed sensor voltage at the plug and it is 12V while right side shows 3V or flatuates when moving the wiring. How often it is faulty wiring from ABS module to sensor?
