hubcentric spacers
gemini
184
Budapest, Hungary
I was thinking about using ~10mm hubcentric spacers, so just made a quick search trough ebay, and found these: click me
but as I have friends working on CNC turning-mill I was wondering are these wheel spacers so uber-hightec? Or you just need decent aluminium material and a few beers for the friend?
I can get longer bolts for cheap too.
any toughts on this?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
I'd try DIY as long as they will be properly CNC'd and so well balanced. the spigot need to be 57.1mm bore, and hole @ 5x100 PCD if that helps
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
if i was you id buy the ones from ebay, saves any problems, plus you get the correct bolts. i have the same ones and the quality is spot on.
gemini
184
Budapest, Hungary
thanks m8 I know the bore and the PCD too.
but what you mean by 'balanced'?
CNC turning-mill works with less than 0,1mm precision.
gemini
184
Budapest, Hungary
you have the 15mm version? there are a few others @ ebay like 20 and 25mm
is 15mm the best compromise between hub bearings life and looks?
DannyC87
Mar 4, 2008
3,459
That'll be fine, just if the tolerances were not so good, you may end up with an out of balance spacer giving small vibrations at speed.
I also have the spacers you have linked to on ebay, 15mm all round.
sambryant
Mar 26, 2009
4,848
Bristol
i have the 15mm and i got them from the same link as you put up. like i said to save any probs just buy them, you dont want to skimp when your own saftey comes into it. id pay £50 and have peace of mind any day of the week :)
