How can I fit these Ibiza red tiger stripe seats into my 1.4 seat ibiza s?
I'm sure it's been done before.
I've got the rears in no problem, but the front ones im having some issues with.
YES YOU CAN!Can I fit the GTI Cupra Tiger stripe seats in to my Seat Ibiza 1.4 S 1999?
- Remove the slide retainer under the front of the seats.(this allows you to slide the chair right out)Unclip the plastic rail cover on the center rails, and unclip the end caps on the outer rails.
- Slide the chair back untill it falls out of the rails, and remove (this is realy good time to give that carpet and old vac down!)
- On your new seats, remove the plastic trim around the bottom of the seat, and swap this over with the trim from your original seats.Otherwise the trim will catch and you will not be able to fit them.
- slide your new Chairs in, be sure to line them up properly, its easier if you have one person infront and one person behind to guide them in.
- replace the retainer bolt on the front of the seats and adjust to your own driving posistion!
- enjoy!
