DPF-equipped engines have a risk of increased engine wear due to oil dilution and also the risk of the engine "running away".
During the DPF regeneration extra fuel is injected at the end of the ignition cycle to burn off the soot in the filter. The excess fuel can wash past the piston rings and into the sump, where it dilutes the oil and reduces its efficiency. This can be detected by an increasing oil level.
Have a read of section 3.2 on page 8 of this http://www.opsi.gov.uk/si/si2009/em/uksiem_20093277_en.pdf, it helps to explain about oil dilution due to biodiesel.
Also check outhttp://www.biodieselmagazine.com/article.jsp?article_id=2290 for more information surrounding biodiesel and the problems with 7% bio and DPFs.
With the bio part of the fuel building up in the sump and causing the oil level to rise, there is also the risk of engine "run-away" where the engine self fuels on its own oil instead of diesel, and where it can't be turned off.![]()
Yep, good (but worrying) reading. I like the fact that the Govt thinks "neutral wording" ie: yes this may bu&&er up your engine but don't worry about it! is a good idea...
Are DPF-equipped VW TDI's ok running on 7% bio-mix? The Govt report claims that: "...increasing the biodiesel content of diesel allowed by the standard to 7% by
volume. This was in response to revised advice from the automotive industry on the
biodiesel percentage with which normal diesel vehicles are compatible."
Hmmm I just hope my 170 DPF TDI is a "normal diesle vehicle".![]()
why dont you run it on Vpower diesel ?
If I have to use any supermarket stuff, I always add a shot of Millers.
Chances are there'll be biodiesel in any diesel you buy from any forecourt in the UK these days.
like Jamborino says the Bio content is going to be much the same wherever you get your Derv.
Paul
That woud work out more
let us know what they say re the Cetane rating & how it compares with VPD or Diesel Extra. Paul
