Looking to remove the factory head unit (Alana - IC Mk4) and replace it with an aftermarket one, can anyone advise how to remove the Stock unit?
also looking to run a power cable for the amplifier, wheres the easiest place to get the cable from the battery through the firewall?
Thanks in advance
Theres 2 slots on the front of the radio beneath the '1' and 'Scan' buttons, you need to slide the release keys in there and it pops out easily.
Relese keys can be bought in halfords, but I just used the ones that came with the aftermarket radio.
As for the power cable I'm not sure sorry, can you follow any other cables through?
Thanks in advance
As for the code for the factory headunit, why do you need to get the code befor you remove it? surely its like VW where u just ring up and get the code from the reg plate?
how do you get it befor you get it out?|
so it shouldnt matter if you have allready taken it out then?
