Does that mean then that stock cooler + twintercooler = ok?
This is what i run JayCee and mine ain,too slow
if you like your air conditioning - S3 + Twintercooler.
if you want the cabin temperature to be hotter than your intake temperature - S3 + AC core removal.
its a simple choice for me.
I did
Logs with S3 core with A/C and without A/C core - will need to try and find them.
As mentioned above, compared with an identical car with a Twintercooler as well as the S3 core also with the A/C core removed, differences were almost negligable.
I did
Ed30 doesn't have the S3 i/c!surprised the Cupra doesnt have the S3 intercooler as standard, all the other K04 cars in the VAG group do, are you sure it doesnt?
Maybe not for now but had some experiences, particularly on hot days even though only running stage 1 with 'heatsoak'
As I undrstand the answer here is more than likely an uprated intercooler.
Personally I like the look of the THS one as it is a direct replacement, used by REVO in their testing and seems to have a good sales patter! However at £600 is a bit steep but probably cheaper than Forge and APR.
I know some have chosen to install the S3 cooler and would be interested in views;
1. Assume like the THS the S3 cooler is a direct replacement (no customisation necessary)
google it
