K04 conversion, help please???
danarmstrong
179
South Wales
Thinking of putting a k04 turbo on my Ibiza mk3 cupra, it's currently got the k03, what would I need to convert to k04? Can I use my existing manifold ect? I kno I will probs need a new downpipe but not sure wot else,
Any help would be most appreciated
ibiza_95
1.8T MK2 Conversion
injectors
MAF
Downpipe (though QPENG do one for the ibiza which is a perfect fit for the conversion)
manifold
oil lines to and from (Oil return may need modifying to clear the rear engine mount)
water lines to and from
Turbo intake pipe
Map
Your manifold wont work, youd need the k04 item
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Have you had a search? There are loads of threads telling you what you need...
k04 turbo with oil & water lines
LCR/TT/S3 mani
LCR/TT/S3 injectors
LCR/TT/S3 MAF
LCR TIP
Custome down pipe
Then a custome map...
Much easier (and cheaper) to just a k03 hybrid..
danarmstrong
179
South Wales
K thanks mate, not as straight forward as I hoped, time to start saving lol, do u know anywhere I can buy the complete conversion kit?
SM
This is more interesting, I believe: (search "frankenturbo" for google. Yet, I can´t write "url")
You will need, maf 3", inyectors 386, and the same of k03...
SM
LCR/TT/S3 mani
LCR/TT/S3 injectors
LCR/TT/S3 MAF
LCR TIP
Custome down pipe
Why you should use the intake manifold of lcr? Interior dimensions are not the same?
SM
inlet is irrelevant unless youve got an AGU coded engine which i doubt he will have...
I think he was referring to the exhaust manifold which you will need for the k04
And yes a k04 manifold exhaust and inlet will fit any 1.8T engine
Ok, I thought, I was talking about the intake manifold, sorry
But, do you know if the intake manifold of the leon cupra R or audi TT BAM, is the same of that the Ibiza cupra mk3?
roly
midnightmotors.net
Jan 2, 2002
1,881
Midnight Motors Workshop
BAM intake manifold mounts the same as the AQX/AYP ibiza mani with the throttle body being on the right hand side as you look into engine bay (it may have an couple of extra lugs on the bottom but apart from that it's pretty much the same)
Injector wise BAM injectors will fit straight into the ibiza mani as that's what i'm running on mine
