Hakko, nice to see your write up here.
I am not sure if it helps, but this may be interesting information.
This is an Ibiza Kit Car Evo 2 rear wheel arch:
More photos needed.![]()
agreed!!!
also if you are gonna widen the rear, have a look into making "stub axle spacers" instead of "hub spacers" as you will go through loads of bearings (especially as it looks like you will need 35mm+)
they sit between the hub and the rear axle (so you need long bolts etc for them)
a guy on clubgti makes them in 15-20mm, but i'm sure he could make bigger if you require![]()
Looking good fella! In need of some rear spacers tho lol..... how have you spaced out the front wheels? I'm pleased to see that the 16" rim don't actually look lost under them arches, thought they would have.
You going to plum in your intercooler next?
Good work!
