No offence takin good sir. I was just askin about they polo mirrors but you got your post in first lol.
(Are they polo mirrors a direct fit and are they both the same size left and right?)
OOOOH who else has TT comps on a cordy?? linky??i have to see this
thanks v much for the kind words!
you can just about get away with fitting a row of orange LEDs under the mirrors.
Wow they look to be fitted really well, are they running adapters or have you converted to 5x100 hubs??
looks nice against the Blue
I hope you don't think im stealing your thunder with the same wheels..... i really had no idea!
Matt
Done properly, no adapters, everything converted to 5x100.
As long as you don't copy everything I'm doing I'm not fussed
Pete
hahaha i wontwhat were the donor parts you used to convert if you don't mind me asking?
and you know what they say, great minds think alike![]()
and yes its loud! and i found that i'll have to dynomat the roof, the rear 1/4's, doors, bulkhead, and pretty much everywhere! all the wiring is now in pipe lagging also, to stop rattles! oh and good job im getting rid of the mirrors.... the covers really vibrate well
The system sounds rather good. Bet it is rather loud when the volume is turned up abit..
Quick question for your, how did you go about doing the smoothing of your front bumper??
okay here's the list
Kenwood double-din HU
Vibe components, mids in doors, tweeters in dash, amped with JBL 200w rms amp hidden in dash
Fli 3ways on rear shelf, not amped just there to fill in if i ever have passengers (hardly ever too low)
2x audiobahn 12" subs, in correct depth box's run by a kenwood 400w rms 2 channel amp (200w about optimal i thought per sub) and just for kicks a Pioneer 12" sub run by a shitty fusion 200w mono amp, this will be removed asap, and replaced by a nice vibe black box and an alphasonik 12" reverse mounted
1 fharad in-phase capacitor, just to stop the dimming at a reasonable volume, not fussed when its cranked up as it will be purely for a min or two to show off haha!
Oh its all wired in with 4awg live and earths branching off to 8awg from the cap to ampsbar the front amp which is just 8wg from the battery itself
I don't need 2awg, 4awg has an ampare rating to 60 amps, which is far more than i'm using, there's no need for 2awg with my setup :S the wiring on my 3 phase 200amp compressor is 0awg..... i think it will be good enough for a couple of 600w (RMS i'm no fool and believe the hype of "peak" power lmao!) amps, the cap is staying because it does serve a purpose, i like quick, hard hitting bass, and it supplies the current when its needed.... thats the idea.... im not saying the way your setup worked was wrong... i'm just saying i won't be changing mine because its more than adequate for the task it has to perform. the wiring to the alt is all new, all earths are new, and the earth in the rear of the car is welded to the body..... i highly doubt that is anywhere other than perfectly connected lol!Ditch the Capacitor
Upgrade the cables to 2awg+
Upgrade the earth cables under the bonnet and the cable from the Alt to battery+
Make sure the earth in the boot is spot on.
You wont get any dimming then if your Alt is working fine. Biggest misconception is that the lights dim on low levels so add a cap. That's the wrong way to fix the problem, it's normally 99% of the time due to poor earthing and insufficient cable sizes.
When I was competing, I was running ~2KWRMS and not a single cap in sight. Oh and that was 2KW of real Genesis RMS not the made up numbers most brands use
Pete
