Nightmare car
welshdragon77
Hi,
Bit naive here but I have a 52 plate Alhambra and I'm struggling to find 3 replacement seat belts for it. All I kind find are mk1.
I saw the topic on here showing a mk2 Alhambra which only came out in 2010!
Wikipedia states Mk1 (1996-2010) & Mk2 - (2010-) but I phoned the local Seat dealer and they 'think' a '52 Alhambra is a mk2???? Help
Also there's a suspicious regular tapping (knocking) noise coming from the engine. When running on stand still it is really obvious but quietens a lot when I apply the clutch.
Seatmann
Rough around the edges
Sep 16, 2010
5,541
10
Scotlanda
It's probably a mark 1 with a face lift but I would've thought the seatbelts are all the same.:confused:
I'm pretty sure it's the same with my Cordoba.
Your knocking will either be the main shaft in the gearbox or the clutch release bearing both of which I wouldn't worry to much about unless it started to get a lot worse.:D
Stabata
from what i can tell the facelift models are the same as the older ones.
i say this as i needed the seat belt clip for my 98 Bamma and got one out of a 51 plate facelift....fitted perfectly and the seat belt clips in fine as well......so you SHOULD be ok with the seat belts you have found.
hope this helps
welshdragon77
No, I didn't get any others, the mk1 one's I bought fitted fine :)
