Woah! So you're gonna be pumping out 200bhp out of an ABF? Sorry I've never really read into this before. Only taking interest in the conversions on here into 1.8 20vT's! I sound tragically novice compared to you lot!
5.08FDtop speed of 50mph LOL
I think I'll go for the 3.94 because with cams, 4 branch, head p&p'ed and a stand alone should see me nearly 200bhp and that should do for a wile. Then gear box and handling and if i do go back to the engine i would prob go for a turbo on to the ABF so i don't think acceleration will be much of a problem then.
Love the colour too! More interesting than Tornado Red... depends what you're used to I guess?![]()
Well Olly you get your head sorting in which way to go about the head mod's.... sort an exhuast manifold, decat, etc (performance advantage along the way) then do the head, cams & map all at once!
On the other hand you could go about the gearbox first, very easy way to get a quick car! If you source another geabox, final drive & diff then you could do a gearbox swap in a day..... instead improvement!
Tell me more about these studs please? I've been interested in these back always in the back of my mind that the studs would become loose, etc.... Where you get them from, how are they fitted (locite, etc) and what wheel nuts have you got?
Good work fella, keep it up and if you need any advice you know where I am!
The red is the standard ibiza red
Dave - I got the studs back when i had my mk3, I found a lot of people on track days and the like use them because it makes it easyer to take the wheels off and on and also you can use spacers or not and any wheels with out needing longer or shorter bolts.
I got them from bill at badger 5 and they are all the same length the rears i haven't cut down because they did'nt stick out to much but the fronts i cut 20mm off and they sit just inside the wheel. (I'll cut the rears down when i get time)
same studs as badgerwagen has used for years,..
i replaced them annually when racing..
no problems.
make sure everything is degreased when installed 1st time with loctite.
