mines are bolted on the side bits of the fogs.
How did you manage to fit the DRLs into the grilles?
LOL! yeah youu go make one on AutoCad! has to be on the fogs, need to get the angles right for the housing!![]()
no matter where i put them could not get tem to stick on
the proper deal only £5.00 i think worth the buy.
And for those who say they look crap when switched off hard wire them in they r DRL, Day Time Running Lights they should never be turned off day or night only when ignition is on.
i bought two large strips of DRL on ebay for my last car no matter where i put them could not get tem to stick on although i might have another go with the ibiza they do look well beside the fogs to be honest.
they r really bright and the proper deal only £5.00 i think worth the buy.
Just find an ignition live wire and u r sorted if you indent them a bit u wont see them when the car is off sure![]()
Not too bad tbh. My personal opinion would be that maybe they would have looked better on the outer side of the grille as opposed to the inner side where you have them. just my opinion though.
Got mine up and running. Tried them before fitting and they seemed bright enough, but now they are fitted and working I'm not so sure!
These are the units bought off ebay
A view once the grille had been removed
Grille with a unit fitted
and from the rear, apologies, it's a little blurred
Feed for these has been picked up from fuse 40 so they come on with the ignition.
Yeah they are like mine but the spaces are pretty tight u would need to cut into the bumper to fit them.
ANYWAY!.....
Below is the proper philips lights they have a "try on my car" section, get a pic of your car and upload to there webpae and u can play around with the lighting.
http://www.led-drl.co.uk/daylight/
