Daytime running lights any pics?
R22 JGB
SEAT Leon FR184 DSG
Aug 29, 2010
304
Gateshead
mines are bolted on the side bits of the fogs.
How did you manage to fit the DRLs into the grilles?
JonDog
LOL! yeah youu go make one on AutoCad! has to be on the fogs, need to get the angles right for the housing! :D
AutoCad is the devil! Would be awesome if you could design your own thing, fair play!
Possibility of getting it rapid prototyped if you come up with something. PM me when you have a model!
anthedge
133
That Audi in that YouTube video looks daft. It looks like its got naff xmas lights flashing at the front!
Jul 6, 2010
66
Northern Ireland
i bought two large strips of DRL on ebay for my last car no matter where i put them could not get tem to stick on although i might have another go with the ibiza they do look well beside the fogs to be honest.
they r really bright and the proper deal only £5.00 i think worth the buy.
And for those who say they look crap when switched off hard wire them in they r DRL, Day Time Running Lights they should never be turned off day or night only when ignition is on.
Just find an ignition live wire and u r sorted if you indent them a bit u wont see them when the car is off sure :)
That's a rather contradictory statement surely?
Park up at Tescos for your weekly shop and they won't be on will they? Unless you leave your keys in the ignition?
Dec 3, 2009
944
I'm sorry but those "strips" you have aren't very good nor they don't have the purpose of DRLs. The ones you have are just for style.
Proper DRLs have reflective housing in them so that the LEDs light can be bright and more intensive and also the beam is more narrow and focus.
You are wrong about the DRLs that should be on at night. DRLs are brighter than dips and fogs, so they are more glarey. They should normally be turned off during the night or dim down to 30% (like Mercs and Audis), when the dip lights go on.
R22 JGB
SEAT Leon FR184 DSG
Aug 29, 2010
304
Gateshead
Got mine up and running. Tried them before fitting and they seemed bright enough, but now they are fitted and working I'm not so sure!
These are the units bought off ebay
A view once the grille had been removed
Grille with a unit fitted
and from the rear, apologies, it's a little blurred
Feed for these has been picked up from fuse 40 so they come on with the ignition.
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,304
7
Desborough
Not too bad tbh. My personal opinion would be that maybe they would have looked better on the outer side of the grille as opposed to the inner side where you have them. just my opinion though.
kw1984
138
Manchester
They do look good.
At least fitting them on the black plastic cover means that if you want to have the car standard, you should just be able to buy them 2 covers as separate parts.
R22 JGB
SEAT Leon FR184 DSG
Aug 29, 2010
304
Gateshead
You have a point but there are two reasons why I located them there. if you look at the foto of the bumper with the grille removed, you'll see there is no so much space for the lights at the outer edge. the other perhaps more important reason is the curve of the front of the car, Currently the lights shine to the front, if they gone further out the lights would have shone to the side so would no have been so visible straight ahead.
I was wishing to locate them at an angle to match the inside edge of the grille so the lights would have been at around 45degrees, the lights were just too long to fit into the grille at the angle. If I'd bought the Ring DRL's they are shorter and I'd have got them at the angle!
Apr 23, 2010
914
Here
I photo-shopped some into mine a few months back, if I ever did do some this would be where I would put them. Might be a bit tight though looking at the photo with the grill removed.
Dec 3, 2009
944
Yeah they are like mine but the spaces are pretty tight u would need to cut into the bumper to fit them.
ANYWAY!.....
Below is the proper philips lights they have a "try on my car" section, get a pic of your car and upload to there webpae and u can play around with the lighting.
http://www.led-drl.co.uk/daylight/
Dec 3, 2009
944
I think you should of stick them where your plate is on each side or should of moved the DRL in abit so it sits flush, u have abit sticking out. Just seems out of place. Good job tho
VRSLOZ
Formally SC16v
May 1, 2010
3,256
Costa Del Hertfordshire
ANYWAY!.....
Good link that one mate, only problem now is that I want DRLs :cartman:
I'd put them here :
Does it look like it has too many lights?
