Top Speed For A Re-Mapped Cupra R?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Off the clock 160mph+ genuinely in Germany, 4 up, on the Kerpen autobahn on route to Schumacher karting from the Nurburgring!
Stage 1 tweaked with 7.5degrees timing advance (Water Methanol Injection) etc!
Henjo24
Ill have to visit this autobahn lol think its called the M4 in Wales aswell :)
TubbyTwo
Taking a break from JDM..
Jan 27, 2010
957
Ipswich, Suffolk
surely it depends on the final gear ratio? more power or mods wont make any difference unless your geared to bo beyond 160 for example.
8bit
3,401
Aberdeen
There is a formula you can use to work out exact maximum speed based on the gear and/or final drive ratios, think it worked out about 162.something MPH for the LCR. Bear in mind that this will look a lot higher on the speedo as they always over-read.
Ronin225
4,652
22
Worcester
Depends on which limits the car, final gear or lack of power to fully utilise it
Effects of drag and aerodynamics will be much noticeable
t32er
every vag car i have been in with a tw@-nav has been 4mph out bar my old cupra, that was 4 out but then i got it to be 1 out when i changed the foil on the clocks to white ones, took me bloody hours and a tank of fuel though, not woth the messing around either lol
Henjo24
I never would hit those kind of speeds mate I have a 2 year old daughter and wanna see her grow up! 1 popped tyre at those speeds and your dead ! Im a slow driver ;-)
