Removing roof lining
jockeh
Im looking for a guide of some hints on how to remove the roof lining in my ibiza.. I need to change the antenna cable as it has been cut off at the end!
Would appreciate some help, preferably with pics ;)
Feb 25, 2007
1,068
cheshire
hi, if your just changing the antenna you can just pop the rear trim off at the back near the boot and the two 1/4 panal trims and drop the back of the lining down you can see it.
jockeh
hey, i need to change the entire cable since it has been cut off behind the head unit
May 25, 2008
2,400
cambs
Well that means removing all the upper plastics a ,b,c pillar then it should just come out
Keep thinking about retrimming mine but never got round to it!
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
if its like a mk2 then it runs along the sills to the boot then up the panel where the top anchor point is for the rear passenger seatbelt then do what MIkey kc says!
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
this is what it looks like in mine :p not bad for first attempt plus all the grey parts are getting flocked
Jul 4, 2010
2,170
Cambs
good job there, looks a bit random with all the light grey trim but once its flocked it was look nice.
was it easy to remove? is it just a case of removing all the grey plastic trim?
i was thinking of retrimming mine in blue camo or something lairy
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
yes easier than what i thought it would be case of removing the grey plastics then there are some 8 plastic pins around the edge pull them out job done
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
Lol I thought that would get a reaction !
Might have to do this over the Xmas break !
what i did was cover lining in evo stick contact glue but the time i had covered every where it had almost gone dry [:@] so got locite some spray glue gave it a coating,layed the suede down job done, could not make my mind up with the fabric did look at white camo fabric but trying to keep it oem+ so the suede suits it better plus with the flocking bits going down to Myki da Pyki should look :bleh:
