darkotics Guest Dec 17, 2010 #21 if limp mode kicks in can i put things back to normal and limp mode will switch off or would i have to get the vag com on it.
8bit Active Member Feb 11, 2010 3,380 3 Aberdeen Dec 17, 2010 #22 I think limp mode only lasts until you switch the car off and on again so you should be ok.
jimbob99 Active Member Oct 8, 2010 340 0 halifax, west yorkshire Dec 17, 2010 #23 8bit said: I think limp mode only lasts until you switch the car off and on again so you should be ok. Click to expand... yeah you can just turn the car off and on again to reset it as it doesnt throw a cel.
darkotics Guest Dec 17, 2010 #24 ok thanks thats good to no so i can experiment a little knowing it wont throw my map out.
