Will do.... Wear gloves if you value your hands.
The problem with the socks is if your stuck then you will find it very difficult to put these on as you need to drive into them to fit them.
You tried this?Spin the wheel slightly(just need goof clutch control) should do it?
I'm quite fancying a set of these for the Bammer.
