coolspot007007
I'm at a bit of a loss for a solution on this one. I went on a 200 mile round trip only for the car to cut out 2 miles from home at 70 on the motorway. No drama, smoke, lost fluids, snapped belts or a rod through the block or anything, just cut out. I tried starting it but it just wouldn't fire into life but turned over fine. I got a mate to come down with jumper cables as the voltage was heading towards 8v quite rapidly when turning over. Even jumpered it was having none of it. I got the AA to take me home and he ran a diagnostic on it - no faults. The lift pump is getting voltage and working, there's fuel to the rail. No fuses blown and I've swapped relay 109 as this seemed to cure a lot of similar problems for ohters but the car was always showing the glow plug light for around 5 seconds so I didn't think this would fix it anyway. I've hooked up Vagcom but I'm not getting any faults. So at this point I'm thinking, crank sensor, temp sensor, ECU (or ecu earth) or a dodgy earth somewhere,immobiliser or tandem pump but I'd of thought it would throw a code in vagcom for any of those. Has anyone got any ideas?
