Hello all,
I thought I'd share my build progress of my Amp box, and install of my sub and components.
I can tell you alread that it wont be as impressive as AndreasA's build here:
http://www.talkaudio.co.uk/ipb/inde...40319__hl__toledo__fromsearch__1#entry3640319
I have been gathering parts to complete my own build in my Toledo and after finding few photo's of various parts relating to upgrading the speakers, head unit ect i've decided to share mine with you as I go allong.
I have had the sub for a while and have been inpressed my its performance, but i've been saving up to upgrade my speakers in the front of the car.
My set up is/will be as follows:
Clarion CZ209ER
JBL GTO6508C Component set
Kenwood KAC-6203
Kenwood Sub (unknown) in ported box
Kenwood KAC-6203
I'm going to have the sub in the boot where i had it before at the very rear of the boot (space is not an issue in the Toledo's cavernous boot)
I will then have a piece of MDF mounted onto the sub-box to fill in the space between the boot floor and ceiling.
To this I'll mount the two amps and on the rear of the box, mount a panel to secure all my wirring and power distribution to.
This is the sub box in question.
I've drawn on the main mounting board where i am going to mount everything and where i need to cut holes ect:
I cut the hole for the sub to protrude through out using a dremel and a circle cutting attachment:
And with two amps in place you can start to see how it's going to look.
The holes are cut to allow wires to pass through. They only needed to be rough because they will be covered soon.
I will continue to update this thread as I do more. Hopefully finish this weekend.
Clarion CZ209ER
Kenwood KAC-6203
Kenwood KAC-6203
