nice results there chaps.. well done.
I look forward to seeing the logs of airflow, boost, injector ms etc
Glad you like the 3inch TIp..
re your boosts, dont rely on liqui or vagcom where you see 2550mb as thats the sensor limit not the boost you're running... you need a gauge to see above this level.. If too high or spikey then I would fear for rods (if) those torque levels are real.
I believe there's quite a difference between AmD's dyno and mine, results wise, in power/torque terms, but before to after gains are gains none the less. It would be interesting to compare a car which had been AmD'd recently here to compare dyno's to understand the comparisons better
nice one.
regards
bill
Thanks for the reply Bill
In terms of logs, I will try to get these as soon as I can and post them up. I think quite a few people want to see what the TIP is doing airflow wise on standard k04 with a stage 2 map.
The TIP is great yes, very pleased
If these figures are true, then I too do fear a bit for my rods I will admit. What route would you take if these are? Uprate rods first of all? Injectors? 4 bar FPR? Am still running oem 3 bar.. Would just like some advice as what preventions to take if any at this stage.
Whether the rollers are accurate or not can be talked about allday as you know, but like for like gains, it proves the 3" TIP has gained me approx 17bhp and torque up from 307 to 330 (+23 lb/ft) so I think it counts when you look at the top end torque for sure. That's where I've noticed it on the road without a doubt, pulls alot harder noticeably 4th gear up.
I would gladly bring my car to you if you we're closer! If someone pays for the petrol I will come down this week to get it rolled and for you to have a look at
Cheers for the post
Tom
Great results Tom. I didn't bother running mine as I figured I'd plough that £35 into FMIC funds but on the road it's brutal
. I hope that when I go Stage 2 in Spring/Summer I can still get a good readout like yours.
Thanks Jason. Pretty happy with how she's performing at the moment for sure. I understand the word 'brutal' at the moment
As in my above post though with Bill, I want to make sure the boost is safe and I'm now looking into what to uprate as a prevention rather than an expensive fix further down the line...
I'm sure your car will make great power. Your using all the right parts and doing each mod with alot of thought, rather than rushing into it. Certainly having the 3" TIP was a great move
Looking forward to hearing your exhaust one day.
