Diesel Particulate filter and engine management light and power loss
JohnnyR1Red
73
Both of these lights have been going on and off for a few months but today driving home all of a sudden I lost 50% power and the yellow coil light came on.
My Leon is a 2008 FR and was remapped about 18 months ago, I phoned a mechanic and appartently my car has gone into 'limp home mode' which I did!
It's still under warranty so I will ring the garage tomorrow but does anyone know what would cause this, do I need to get my remap reversed so it's not detected?
Coops993
51
I'm kind of new to this forum but I would suggest if you look in the TDi section you will find the answer, probably a fault with the filter/ needing cleaning
AndrewJB
Aug 16, 2007
11,163
484
Maranello
Either DPF has had it or one of the Sensors on it has been blown!
A bad remap can cause this as the PD170 DPF is so sensitive that a Smokey remap will fill it full, DPF Isnt covered under warranty so if its gone then look forward to a new one at like £1200
JohnnyR1Red
73
bloody hell, is there no way it can be cleaned
AndrewJB
Aug 16, 2007
11,163
484
Maranello
Dealers can do a forced Regeneration but it depends on how full it is,
There is the option of having the DPF Removed like i have but at the moment VOSA are in the process of changing the rules and it looks like its going to become Illegal to remove them in the next 2 years
JohnnyR1Red
73
any idea how much it would cost to remove it, will be pretty annoyed at the company who remapped if it is knackered.
Deleted member 62438
It might be a bit late now but when i picked mine up 5 weeks ago, the dealer told me that if the light comes on to run the car hot at high revs for a few minutes and it will burn the soot off. Bare it in mind for the future. If this is the first indication from the warning light then i would question whether there is a fault for not warning you earlier.
JohnnyR1Red
73
DPF Light + Coil Light is the big warning
Well I went to the dealer this morning without an appointment but they agreed to look at it for me, I waited 3 hours fearing the worst but they found that it was a faulty gas sensor which they replaced for free :funk:
I drove to work in 4th gear at 70 for about 15 miles just in case there is anything in the DPF and I will do this again on the way home. The problem i have is that I spend about 2 hours a day stuck in traffic hardly moving so I need to make sure I have a good blow out from time to time
Glad to hear you got it done for free.
Use the blow out time to enjoy yourself lol.
