that would do it i dident know it was that i thought it was the map
sorry mate dident realise i sold her to you with a crapped clutch.
anyway ramble over i took over your thread talking crap lol
i think your next step is to dyno it up and get a defined answer to what you need next.
if only badger 5 was closer....
still your car shifts i wouldent worry too much
mines only 189bhp at the wheels bager 5 dyno yawn
400bhp engine haha
another thing is it spools up quick as anything too, its a full chat buy about 3000rpm and the needle just doesnt move
A k03s should be fully spooled by 2.5k rpm (ish)...
Thats deffo a k03s..
Maybe a stupid question but does your wastegate/actuator work??
I think the Turbo keeps spooling up.
Can you check crack pressure on wastegate, unplug N75 see what it boosts to? Might give some indication as to whether or not the gate is being held closed for too long...
I have bypassed the N75, it is running a Forge Unos MBC. (N75 still electrically connected though) But with the N75 it used to spike at like 35psi.. thats why I got the Unos now I have set it to 24psi spike..
If i wind the MBC right down it wont overboost.. it will hold what ever its set at.. so the wastegate/actuator must be working..
I would not be driving this hard to be honest, 1.5bar of boost or more with maxed out injectors says lean to me.
You need a wideband setup ideally to check whats going on then possibly new injectors and a maf.
