Yes I dont normally, I just needed to for logging. Iv wound the boost right down for daily use.
Part of me is thinking get BAM injectors, MAF housing & Fuel pump and stick an early S3 stage 2 file on it and see what happens.
In effect set it up like a hybrid.
Does anyone have any oppions on doing this as I will be ordering all the parts tomorrow..
yes. I have heard this is a method used with revo.. not one I subscribe to however.
flashing an early S3/TT file into a 6k ecu is a bodge (albeit it works)
fpr is dependant on software used.
I use 3bar, no need for 4bar
The standard 3bar fuel pump 'should' be ok to use then?
Out of interest how much would you charge to map it?
hmmm. not always. several of the ones I have done have needed pumps when it came to mapping..
my stage 3 is £550
I would like your oppinion on doing what I am proposing.. the thing im worried about is just because its holding pressure high up doesnt mean its flowing as much air as a hybrid does it..
thing is you have to ask how/why is it holding up pressure at the high rpms where normal k03s cant...
it *should* be flowing more if its sustained 1.4bar boost @ 6krpm, and again if its not I would also be asking why/how is this? - hybrids will flow 220g/s approx on 1.4bar at 6krpm
your throttle is opening fully is'nt it? (log block 060 and see)
Thats exactly what I am thinking.. WHY is it doing it, I only realligned the TB the other day but ill log 060 tonight. Any others I could log to rule out anything else?
