best oil for PD
Red Panda
368
Not telling
Mobil 1 ESP quietened down my FR Tdi for sure. I believe Castrol Edge 507 is slightly more viscous than ESP but both are great TBH
Nam-uk
1,273
417
lancashire.
Red Panda
368
Not telling
I think I'm right in saying...
507 is a newer spec oil and is suitable for long life service intervals on PD's and is compatible with DPF engines (5w 30)
505.01 is for fixed service intervals on PD's without DPF (5W 40)
Have a look on Opie Oils website. If in any doubt as to suitability send Opie Oils an email...they'd be pleased to help I'm sure.
Here's Mobil's website which has a 'what oil for my car' option.
From my own experience my engine runs a treat on ESP and quite a bit better than on Millers XFE-PD 505.01 maybe because ESP is fully synthetic? I don't know but it just does :)
822
Mobil 1 ESP i just used, car seems to more responsive but the old oil had been in for a long time, but its awesome stuff for PD engines upposedly.
fr930
Got SMOKE...?
Jul 28, 2010
89
London
have been using quantam platinum in my fr tdi, next oil change will be castrol edge td..
only have a 4litre bottle so guessing will need to get hold of a top up? used about 4.5 litres in last change
Nam-uk
1,273
417
lancashire.
mine is the mk1 tdi leon without dpf and Opie still say 5/30w , seat told me today DPF engines need 5/40w which i thought and read they need 5/30w:confused: then i read that on the castrol site saying Pd engines need 5/40w which can mean all Pd engines.
this is getting a bit silly i can tell you,
what a fixed interval? is not the oil change every 10k.
oldtime fitter
19
Brentwood Essex
would this oil be suitable for a standard tdi 1.9 Sport. Ford formula F Synthetic oil (WSS-M2c913-C/B/A. ACEA A1/B1 by the price!! it should be, but i would like to be sure
Red Panda
368
Not telling
Sorry for the delayed reply I only just saw your post.
Your saying Seat state DPF's need 5w-40 sounds a bit weird to me. 507 which is DPF compatible isn't 507 without it being 5w-30
The easy answer is both 505.01 and 507 are good choices.
Arguably 5w-40 505.01 has a wider level of protection than 5w-30 - however 507 is to a standard which VW reckon is good for extended service long life oil changes...so I kind of believe it to be of a higher/newer spec than 505.01...I might be wrong though :) 505.01 must be changed at 10,000 miles or sooner whereas 507 can go on quite a lot longer.
On an American TDi forum they have oil discussion threads which are seriously long...just arguing about which oil is best for PD's. A lot argue that 5w-40 Mobil Turbo Diesel Truck is the best oil for VW PD engines - but it aint 505.01 or 507 rated by VW so your warranty would be voided. The more I looked for an answer the more questions were raised so I gave in and just got some 507 Mobil ESP cheap at Asda. I'm happy to be using a top spec oil and it'll do for me.
Red Panda
368
Not telling
No :) get VW 505.01 or 507 spec oil. Good value 505.01 fully synthetic oil would be Quantum from a dealers. Be careful though as I believe VW stealers are dearer for the same oil than Skoda and Seat dealers. Quantum Platinum 5w40 505.01 for 5litres is around 25 to 30 quid and the Quantum 507 oil is anything up to £55 in a VW stealers.
Here's a thread from Briskoda about what oil to use
Nam-uk
1,273
417
lancashire.
no worrys mate, no the Castol site says 5-40 for the Pd engine,
but what i got in the end was 5-30w oil due to Low ash , what i mean is the the lower the high rate the lower the ash i.e i got 5-30 over 5-40, the DPF does not matter to me as i have a MK1 tdi leon PD engine , but if i ever got a DPF filter engine then it still would be the lower 30w rate oil , thing is you have to look in america they have a hotter Climate in summer ect in uk were not the same Climate, so the 30w oil would be a better option.
RLyons
310
SO far in my pd 150 I've had;
Castrol Edge - OK
Millers XFE-PD - Noticably smoother
and I have just had some Fuchs Pro S 5w-40 put in, which it is the best by far - smoother than the Millers. It's not officially a PD oil but am reliably informed that it far surpasses the PD requirements....bloody expensive though!
Red Panda
368
Not telling
It's funny that the Mobil site says ESP 5w30 for the PD...and Castrol say 5w40 :)
Red Panda
368
Not telling
Castrol Edge - OK
I used to be quite the Millers fan but after using XFE-PD I wasn't too keen TBH. I put it down to it only being a Semi Synthetic and decided to use Quantum Platinum 505.01 fully synthetic after that. As it happened I then found some ESP for a great price at Asda and bought a load of it so that was problem solved. Comparing ESP to XFE-PD my engine sounds smoother.
oldtime fitter
19
Brentwood Essex
Ford branded oils including S/SD 5W/40 are produced by Castrol for Ford Motor Co . the tdi 1.9 sport rider handbook states (A) Multigrade Synthetic oils with a spec VW 505 00 and (B) Branded Multigrade Synthetic oils with a spec VW 505 00 or API-CF or ACEA B2 or B3. On the Ford container is the following
WSS-M2C917-A . ACEA A3/B4,C3. (API SM/CF )the last set tie up with the handbook spec. O for the days when oil started with a simple SAE 10 with jumps of 5 or 10 till you got to 50.
