I had a custom variant of that can made by forge as i was the trial LCR they tried to fit it on
Have a look in my RR at the pics, it will be mounted off rear airbox bracket
As said aircon gassing point fouls this but i seriously reckon bracketry to support it 40mm lower could be easily made. I have even offered to do it just to prove it
Do you have any pics of the tank fitted??
Yes as long as they have 19mm inlet and out lets, NOTHING smaller or you could have problems in the long term.
my fittings are only bolted in, i may go and get some 19mm fittings to bolt into can...
Any one fitted one of these
http://www.pimpmyskoda.co.uk/V2Images/ModsEngine/OilCatchCan.htm
Ohh deff gona have to send him a email then
As I'm thinking of one like the square one your getting but with 19mm bent connections on it so I can sit it at the front of the bay with the connections pointing towards the fire wall
I've removed mine if they don't have 19mm inlets and out let's they cause damage to the engine so catch can is the the garage I now have a pipe coming out the rocker cover going strait to the floor :)
Hi There, did this affect your car? I can't find a 19mm catchcan (in the Uk) and my pcv & oil breathers are in a state, so need to sort.
Sent from my Nexus 7 using Tapatalk 2
Someone somewhere (HERE) stripped a hockey puck down (with a knife/saw) and found that the orifice inside is way smaller than 19mm, showing that you dont need 19mm in/outlets on your catch can :)
thanks
Thanks for posting that guys, would 15mm hose through out be ok then? as the pcv hockey has this smaller diameter.:confused:
