Big turbo 1.8t Golf with the luxury of AWD
caney
600
Awesome,love build threads like this where people do the work themselves:clap:
calvinvw
that must being insane when , curious to no the driveability which such a big turbo on a 1.8,
The driveability will not be so good turbo won't come in whilst 5k an hold on the rev range to around 8.5k with around 28-30psi, i intend in future make a 2.1 which will be a better car day to day i intended to do this now when ive run the engine for a year or so. I have a new VW Fox 1.2 for day to day driving which i will keep standard so will only use the golf for weekends.
Thanks, i have done pretty much everything no one has put a hand on it as yet so if it dosnt run i know who to blaime :D The TT looks good id like to see that!
Cheers for the comments.
calvinvw
Only a small update, till next week when the engine gets mated with the gearbox for the first time an in the 4mo.
So got some vacuum now brake servo will run staight from one an other will be for vacuum manifold to keep it all tidy.
All done, just more sanding then polishing.
calvinvw
Looks good mate, you've got some skills ! Also love how you built an engine then bought a car to fit aroung it !
Keep it up mate.
Cheers, just been caging the engine bay right now hopefully the engne fits :p if not ill be modifying the strut brace alittle before paint i am not running a cross member so will have to brace the legs together to. Anyway a couple of photos to keep my thread going hopefully its up to scratch for you lot. [B)]:funk:
calvinvw
If anyone interested shell is for sale £800 with running gear interested in a rallye now.
calvinvw
ANYONE INTERESTED ON ENGINE PLEASE LET ME KNOW HAVE TO ABANDON PROJECT WILL TAKE £5000 NO OFFERS SPENT WAY MORE THAN 10K WITH RECIEPTS FROM IE FOR COMPLETE ENGINE
MAHLE 82.5MM PISTONS 06A REBORRED BLOCK
KINITEK MANIFOLD
GT3582R TURBO with 63ar
TIAL WASTEGATE 38MM
TIAL BOV 50MM
AEB CYLINDER HEAD
SUPERTECH VALVES INCONEL EXHAUST WITH NEW VALVE SEATS
SUPERTECH VALVE SPRINGS AND TITANIUM RETAINERS
DMS HEAD GASKET 700+hp
IE CONNECTING RODS
NEW OEM BEARINGS
ARP MAIN STUDS
BALANCED CRANK, SINGLE MASS CLUTCH MASTERS FLYWHEEL, CLUTCH SPEC STAGE 4
REINFORCED SUMP
CUSTOM INLET MANIFOLD TO RUN R32 TB INCLUDED
NEW BOLTS ALL ROUND
NEW OIL PUMP AND TENSIONER
ALL SEALS, GASKETS NEW VW
ARP CRANK BOLT
TT QUATTRO 6 SPEED GEARBOX WITH NEUSPEED SHORT SHIFTER
SMOOTH ROCKER COVER
20V NA CAMS
ADJUSTABLE TIMING GEAR
IE TIMING TENSIONER DELETE CONTI BELT
VW AUX BELT NO AIR CON
100's of VW RECEIPTS AND ENGINEERING THAT HAS GONE INTO ENGINE IS CAPABLE OF 650HP COMES WITH MK4 GOLF LOOM AUM FULL AN ECU CLOCKS KEY SKC CODE
WILL PUT ON EBAY IF NO INTEREST HERE IS GOOD PRICE CONSIDERING TURBO WAS £1000.
WILL SELL ROLLING SHELL MK4 GOLF 4 MOTION 3 DOOR WANT £400 CAN DELIVER POSS. A RARE FIND.
07814747676
liam86
why would you sell after all the hard graft you have put in mate .
calvinvw
i have other commitments with my unit im doing up for body shop, i cannot no longer keep an on going project i also have 7 other cars which have to go. It wont keep me for long i just bought an S4 which ill have big plans for in the winter when works not so great but been real busy an needs must have to much work on :rolleyes:
