Did I miss something or is it transparent vinyl?![]()
I would have gone for the wingnut mod Arun. You would have kept the ASV so engine shuts down nicely and had same gains cause the EGR would be clean. Anyway looks good!
http://www.seatcupra.net/forums/showpost.php?p=2442333&postcount=1081I dunno what the wingnut mod is, i'm assuming its the blanking plate/blocking off the vac hose?
EGR is crap anyway, except help emissions (which is smoke test, and can pass with a decat and no EGR anyway)
EGR is clever in theory, in practice is a load of crap, so removing/blocking it is a great idea IMO.
I will be blanking mine off soon![]()
Gut out the plunger on the EGR. Take the opportunity to smooth it all out and clean up the EGR also. Leave the ASV in place and plank of the bottom. Remove the VAC hose and get the EGR error mapped out of the car...works same as the racepipe with less chance or a runaway and clean shutdown.
pah! sumps are strong barstewards........ well, until they hit something sharp
I want to do my EGR too.... you got any error codes? and what egr removal kit did you get![]()
.......Well mine might be Sumps strong? My arse lol, I cracked mine open on ice ffs! Wheel went into a rut and smack! piss piss piss all over the place. As for the egr you can turn the effer right off in vagcom, that's what I've done for now, thinkin of butcherin it though.Dremmel dremmel dremmel, file file file, rub rub rub with wet and dry, ooh it sounds like effort.![]()
nice looking bora, you are pretty lucky with that sump it doesnt take much to crack them, mine is currently half chemical metal, you should look into getting the one with the steel bottom they are only £80 from david at sere
