You have Done a lot of work in a short space of time, and car looks great just had a read from start to finish hats off to you for all the work you have done!
You have Done a lot of work in a short space of time, and car looks great just had a read from start to finish hats off to you for all the work you have done!![]()
It's all about the flush right now mate haha.
Look forward to pics
15mm on the back is the one!
I wouldn't change them on mine, looks so flush.
Lovely Leon mate,are you running a Jetex cone i see? I was wondering if it was as im after one of those Jabbasport heat shields and wanted to know if it fits with the Jetex?I have the Badger 5 3" tip and jetex set up on my leon...Do you know if you can buy that heat shield seperate?
cheers
Tom
Hi mate, thank you for the kind comment. It is the Jetex filter and Badger 5 TIP I have. I too purchased the Jabba Heat Shield separately. I also have a 3inch cold air feed which fits perfectly. Have a look at this thread I started when I was inquiring about the heat shield: Jabba Heat Shield
Thanks for the reply
Did you get your heatshield direct from Jabba?
I shall take a look at the thread now,cheers!
Tom
The heat shield also stops excessive MAF movement, a previous theory for MAF failure!
No problemo. I did indeed mate, great bit of kit. In my opinion open cone filters look lost without this style of heat shield
Bring it round one day and we'll do some mate![]()
