anyone have this??
sheps
Off topic did i see you on track at combe a few weeks back?
Apr 15, 2009
2,188
Midlands
Its different to a wot box, have a read of the description
Wot box is for clutch-less gear changing and holding boost through gear changes, plus launch control
This is different
Its a rev limiter that still allows fuel to go through by not cutting fuel at higher rpm's, giving bang bang and flames at high revs
They sound mad on tuned jap cars, never seen one fitted to a seat though
Apr 15, 2009
2,188
Midlands
Are you sure your not thinking of a wotbox
I cant see how this can do anything to engine internals
Its just a rev limiter which allows fuel to go in and ignite
At worst maybe the extra heat could potentially cause long term stress on the turbo/manifold due to the heat but engine internals shouldnt suffer surely.
Apr 15, 2009
2,188
Midlands
Its says additional wiring may be needed if you have an aftermarket ecu, works on standard ecu
Some addional wiring may be required if using in conjunction with an aftermarket ECU
Apr 15, 2009
2,188
Midlands
I thought it could allow gear changes without the clutch aswell as not having to lift off the gas?
Seen yanks on youtube doing that
cuprabaz
Racing 2020VT
Jun 22, 2004
2,291
Aberdeenshire
As far as I'm aware it's the activation of the clutch switch that triggers the ignition cut taking the load off of the engine/transmission to allow WOT shifting.
2,188
Midlands
Oh right my bad than
This does look interesting and from what ive seen alot of people only buy wot box for the bangs and launch control and to show off lol
This bee r limiter could be a safer way to get that i can see it becoming popular once a few people bite the bullet and buy one
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
18
glos.uk
apart from those who suffer engine damage...
did'nt a guy on here explode his engine the 1st time he used it?
full throttle, abrupt off loading with an ign cut, and back on again?
think about the stress's involved and ask yourself will my Standard engine cope with this?
