Apr 6, 2010
543
Just wondering what i would need to install this in my leon mk2. I have multi functional steering, parking sensors, bluetooth, aux etc, will these still work? I have the cage, remote, mic and power wiring. Unfortunately when i were removing it out of my old car the trim that goes around the deck broke, will I need this? I already have the double din fascia which I ordered from sere although theres around a 15mm gap between the fascia and deck is this where the broken trim will go? If so where can it be purchased?
You will need a Golf Mk5 double din adaptor to get rid of the gap, a steering wheel adaptor from connects2 to work the steering controls. Bluetooth, aux is built into the stereo anyway so dont know if the factory ones will still work. And regarding the pioneer trim, try contacting pioneer themselves as i doubt it can be purchased on its own. As im sure this is the same as the 3300-bt
Hope this helps
Ebay item number 260693334055 is this the fascia panel? On connects2 is part number ctsst001 the correct one? thanks for the help.
Yeah mate I seen them on your old thread yesterday but ain't working even these links ain't but I ordered the fascia for the vw.. Thanks again
I found this:
"The 3300 seems to have a French as one of the multi language displays, App mode: "App Mode selected, you can operate the unit's iPod function from your iPod. Also, you can listen to the sound of your iPod/iPhone applications through your car speakers and view any video content on the screen, provided the App supports analogue audio or video output." and that's about it! There might minor other tweaks like bigger SD card and the use of newer iPods."
Would presume its just the Appmode which is the most noticeable other than that, they are the same i think
I found this:
I would have thought it had sat nav..
