in my sig
trublue, why dont you just go for stage 2 since you have the exhaust?
Hi Guys new member just wondered what you guys think should be next mod before remap, i have a 2002 cupra but its only the baby 180 bhp.
Its had turbo back cobra sport exhaust, Forge recirculating valve and i have smothed the air box and fitted a green panel filter and got a 3 inch cold feed pipe to the back of the light at the moment an ideas???
Yes thanks 8bit i was looking at a Silicone turbo intake pipe (TIP), have you any idea what i should be looking at hp wise with the tip fitted and the stage 1 as i cant afford the Intercooler yet ???Silicone turbo intake pipe (TIP), then you're good to go for stage 1. If you want to go straight to stage 2 then you'll want a front mount intercooler too.
Someone was asking about the Revo linear map - I had this put on mine a couple of weeks ago, was on standard map before. Car feels a bit more predictable and civilised at low RPM/normal driving, feels pretty brutal under high boost. The state of tune is the same as normal Revo (i.e. same boost, fuelling etc), it's just the throttle response map that is different - it's linear now (hence the name), so 50% throttle pedal = 50% throttle plate angle. On the stock throttle response map 50% pedal might = 75% throttle plate.
I haven't had mine properly logged or on a RR yet but I did a quick 3rd gear run using the Torque app for Android and saw a peak airflow of 210g/s, which I make out to be 262.5bhp. That said, I didn't quite hit the redline and I was in 3rd, not 4th. I'll hopefully get some logging done this weekend and post back.
Did it cost you much to upgrade to linear map?
Torque app... What phone do you have this on? does it plug in to car?
I use momentum 99.... whats the thoughts on that fuel?
Momentum 99 is great fuel.
My car was mapped at AmD and was religiously using v-power. I have used tesco 99 recently as my Shell has been closed down for refurb and not noticed a difference in performance. Only thing I would say is the exhaust seems a bit 'sootier' than when running v-power.
I found I got a bit less mpg out of the Tesco stuff than V-Power but I didn't notice a difference in performance, both were equally good.
try a open cone filter. good results. good sound
bit of lag though
