Soopacoop Lcr rota grid drifts , ksport 8pots ,stripped and caged
Dan1720v
1,928
Street, Somerset
Still racing on a public highway. Doesn't have to break the limit. But, you can work out your average speed by counting the white lines. Speed =distance/time. The white lines are a set distance apart, so it's not rocket science.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Tom found this :)
Jun 20, 2010
1,296
Norfolk
Dan did i read that you added camber or were going to?.. or was i dreaming?... Im after a way to add some on the rear of mine, and didnt know if you had done..
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
I haven't added it yet but you can , same as how golf mk4 are done give it a google but you need to either get camber shims or you can use washers in the rear hub , you need to remove the disks and undo the bottom two bolts slide washers in and do it up if you go to much you have to space the rear caliper as well
eta76
Flying dutchman
Jan 6, 2012
77
Cool car ! Nice work you did on the front arches. Massive wheels so it seems.
