my lcr did 38mpg going up the m1 to nottingham at a steady 80mph last weekend it normally does around 25-30mpg normal driving but i've had it to low 20's when booting it.
what voodoo magic are you doing to get those number
An LCR is pulling approx 3250rpm in 6th at 80mph, so I guess vwdom's is off-boost at 3250rpm??
In
theory, don't see why an LCR shouldn't do that sort of MPG when cruising? After all, it's only an 1800cc lump. Most Euro-designed cars are mapped/geared to run efficiently at the average European motorway speed limit - ie 130km/h (80mph).
And tyre-width aside, an LCR effectively has all the slippery aero kit a BlueMotion-type car has - ie side-skirts, low front spoiler/splitter, front undertray - so an LCR
should return decent MPG when cruising - but the reality seems to be different.
It seems odd that LCR owners seem to genuinely report either approx 37mpg or 28mpg at motorway speeds.
My LCR used to do 34-37mpg at motorway speeds, now it's dropped to late-20s.
Makes you wonder if there was an inconsistency with ECUs or some other component during the build process, or when LCRs reach a 'certain age' they start to use more fuel, or...??
