Your bang on the money, comparing different dyno graphs isnt ideal, however its slightly more comparable than normal when both graphs have the stock Bhp/torque on them and correlate pretty well.
So if the stock curves correlate, the tuned curves should be near enough on the ball as well.
The 0-60 doesnt mean much in real life terms though as you are flat out in the top end of the rev range. In gear times are what matter in real world driving, where your say in 3rd gear at 3000rpm etc, thats when a difference of 40Hp/40lbft would be very notable. Then theres the timing gear etc, some guys have used high tec GPS laser testing equip, others have used I Phone Apps on the local hill,
You can easily drive around that though, by changing down the gears before you accelerate. An example of this: The Clio RS200. similar power, but low torque, and performs the same as the other hot hatches when driven at the redline. but in lower speed, higher gear scenarios it loses out to all the other turbo charged cars.
Id bet your car will be every bit as quick down the 1/4 mile as all the other stage 1 cars.![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Am i right in saying you also have an intake?
