New wheels purchased, preview pics!
May 1, 2011
630
North West
Direct from the good ol' US of A
Here's the state of boxes I had to cram into the car without using bootspace (sub)
The top box is a 225!! :)
And here they are!
I'll be testing them on the weekend for room in the arches, won't b able to afford tyres for a while :(
Oh and the service light is on and I think I have a boost leak and my stereo is fooked again....Love this car and it's bad Karma.
May 1, 2011
630
North West
Cheers mate! they actually worked out cheaper to import than to buy in the uk!! And It's hard to find this colour here.
Sep 4, 2009
736
rainsport 2 are brilliant. thats what im running. even a suprising amount of grip in the snow. (although i dropped about 5psi out of each tyre for the weather)
Dropping psi is not always better for snow.
The Pirreli pzero rosso i have are great. Nice looking wheels too, cant wait to see them on.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Dropping tyre pressures is an ancient trick used by trials cars to get better grip in mud. Won't help on the road. In snow, higher pressures are sometimes of use to get the tread pattern to cut into the snow more effectively. On ice, nothing helps. Well, maybe studs. Or an anchor.
Mucking about with tyre pressures is a good way to cause an accident.
May 1, 2011
630
North West
They were going to be my original choice purely because of how good they're supposed to be in the wet and snow. But then there was a thread on this forum about Best tyres and contact 3s came top, or near, partly cause of how gud they are in the wet as well and when I priced them up they're not that much dearer.
Cheers mate! I'll check those tyres out.
What J are they ?
They're 9j mate, couldn't brave the 9.5 in the end! Oh also, I'm right in thinking you tested your wheels on wood blocks right?!?! Starting to get worried about what to put between wheel and wood so I dont put all the pressure on one spot.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Don't think Leon arches can be rolled I have et38 on the rear of mine they didn't fit with a 8 mm spacer on the front , you going to need some serious stretch on those tyres to make them fit. I would say either a 215 or a 225
May 1, 2011
630
North West
why?!?! Your rears fit a 9.5j with a 8 mil spacer, Your et is 38 so would only need 5 mill spacer for 9.5 and I'm only 9? What have I missed?
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
The rear has no spacer et38 and about 10mm clearance if that , the fronts are et23 8mm spacer the et38 on the front with the spacer catch on the coilover adjuster and caliper
May 1, 2011
630
North West
Hmmmm.... Gutted, I'll have look tomoz I guess. Wanted 235s on there tbh as well but nvm. So if your offset is 23 with 8mill spacer ur lookin at ET15 so for me would be 20 mill spacer on a 9.5j. I found a website that told me how much these new wheels would poke out each side and it looked pretty even on both sides. So could I not guesstimate that I'd save about 10 mill Inside and out?! Is that completely stupid? I already know it's partly stupid.
