Jodrell
61
Hi.
I have managed to fit a VW RCD 510 with DAB to my 58 Leon Fr with some great help from you guys on this forum!
However, on the back of the new head unit there is a double connector for the FM/AM and I only have one cable from the original radio.
I fitted it to one side and it seems to work but not listing all the stations in my area.
Is there an adapter cable to go from single to dual feed?
Also, what do you recommend for a DAB aerial that doesn't involve ripping the car apart but has pretty good reception?
Cheers!
Hi there.
It's a single fakra on the car and a double fakra on the radio.
I hope there is a double adaptor or something to connect it properly.
Cheers.
Jodrell
Hi mate.
I cannot thank you enough!
I have been looking for exactly this adapter you linked to for over a month. I had resigned myself to it not being available.
Do you just plug the car end into it and then straight into radio?
If so then that's it sorted!
I owe you a pint!
Many thanks!
Jodrell.
Yes fella plug and play dead easy,glad to be of help.That link in earlier post is the person i bought mine of.
I have one of those for my RNS 510. It works well but the only problem is it causes an error to appear when you do a VCDS scan. But its a false error so you can ignore it.
Cheers guys!
Thanks for the info.
One ordered immediately!
Just need the dab antenna now and it's finished.
The link in my other post is the one i use with no problems at all as mine is single on the car wiring to twin on the back of my rns 510.
Hi Guys
I think I have the wrong one. There must be a good reason why there are twin antenna points. If I use my current ordered one then I will only be using one of the twins.
Ill order one from the links you left.
Thanks very much for your help!
Rich
Hi, bit of a late reply but is this the same error here -
1048632 - Antenna 1 for Radio
B1119 13 [009] -- Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 47
Reset counter: 94
Mileage: 89170 km
Date: 2000.00.00
Time: 20:48:32
I've used a jvc aerial that's DAB and analogue for over 5 years now and been on several cars. Had to take the plastic shroud off the back of the rcd 510 to make it fit though
