hardcore4
68
Hi guys looking to get some spacers for my lcr to bring the wheels out a little, are 25mm the ones to go for and where is the best place to get them from?
Cheers!
Aha,
Well instead of starting a new topic (as I was literally about to),
I'll tag onto this one (Hope I can)
I have 25mm and 20mm spacers sat at home from my Mk4 Ibiza, I think their 5x100 57.1
Can you run 25's on the rear? or is 20 the max? I only ever saw people running 15mm on these forums.
Mine is running 20mm alround
yes the car is lowered. Where di you get those from lee and what measurements are they?
Also depends on offset/width of alloys.
best thing to do is try it! If you get rubbing or dont like the look then take them off!
help, whats best thing to do having 3mm spacers on front to clear brembo's with my pro race 1.2's. Whats should i do with the rears?
Car is running standard height on FSD's
get 3mms for the rear too! or dont do anything on the rear! 3mm isn't going to affect your handling that much.
The fronts are by standard wider than the rears. Think having a wider front keeps it more stable. Is 3mm the most you want to go out on the front?
i think so yeah, was happy without the spacers but the wheels could do with the 3mm clearance as i'm getting rub marks on the caliper , just wasnt sure about what to do with the rears. seems most people are having more spacing at the rear wondering if i can improve handing
wheels are 18" et35 with 225 40 /18's
Reason people normally have more spacing on the rear is just to bring them out for looks. They're quite big arches so have more room to space them out. Handling will be best if you keep it even all round.
