Hi all,
After taking somebody out in the car the other day, drove fairly hard, I parked up and after letting turbo cool for a bit I switched off. - The engine fans were still running and continued for a few minutes.
Ordinarily I would think this was fine, however now, and since, everytime I drive the car and switch off the fans are still running.
I can now only assume there is a problem.
I have lifted the bonnet to check for obvious steaming or oil splatters, low coolent etc but all seems fine - just a bit warm in there and radiator fans running
I have had issues recently with my dashboard temp gauge (water) It will get to 90 then drop, it may keep going up and down in the range below 90 but never goes above 90 - after research I am led to believe that issue is probably the thernmostat, please advise if you feel this is incorrect? - This is an unrelated issue though I'm sure as been like it for about 6months. I am just concerned though as I can't help thinking my temp gauge would not tell me I am overheating now though if its faulty (although like I said it never goes above the 90 mark)!?
My concern now is that because my temp gauge is misleading and the engine fans remain on when I've left the car that I have an overheating issue or may be damaging the engine somehow!? Due for a few long journeys I'm obviously concerned and certainly do not what gasket issues etc
Please advise guys, much appreciated as always
